I have internal wastegate.Where is the best place to hook up my wastegate hose to get a good boost pressure. I have manual boost controller. Just need to know where is a good boost pressure source on the engine, so it will force the wastegate arm to open. I was thinking drill a hole on the throttle body pipe and install a fitting and then hook up the wastgate hose to it. Thank you
